Can you help me ID this fuel pressure regulator?
Kikwear
1,437
Carbondale, IL
I have a regulator left over from my 97 Cobra and I'm trying to identify the manufacturer so I can sell it. It looks identical to a stock regulator except the vacuum nipple has a threaded screw to adjust the pressure. The P/N printed on the body is 185JJBA. Thanks for your help.
Sorry it took so long guys. Here are the shots.
Kikwear said:
Tim, I don't think stock regulators have an adjustable fitting on the top to regulate fuel pressure. The one you linked has an open vacuum fitting, like most stock regulators.
Was is a stock FPR that has been modified? That would be my only guess because I thought they all needed vacuum.
Tim
They do need vacuum. I remember removing the hose, adjusting the fuel pressure and then replacing the hose back on top. It does not remain exposed. As far as modification, I can't say. I remember buying it that way from a friend.
