Can you sand or fix a scraped dash??
  • Thread starter Thread starter Black Stampede
  • Start date Start date May 1, 2010
Black Stampede
1,811
Grand Rapids, MI
May 1, 2010
  • May 1, 2010
My manual high speed fan switch was bad so I swapped out for a nice new one and when I was drilling the hole for it the drill bit popped out and ran along the dash for like 6 inches. I was SO mad. Not to mention I have a black dash so it shows badly. It is directly to the right of where your right knee would be while driving. Not the worst possible place but still looks like crap. Can this be sanded in any way or am I pretty much screwed cause I would sand the texture off the dash too?
whitesqual
235
Coeur D'alene, ID
May 1, 2010
  • May 1, 2010
The previous owner of my car had glued a dash mat down. When i was trying to remove the glue from the dash, I scraped it up a little bit. I thought I was gona have to buy a ney dash to get it to look right. I used some Meguiar's Natural Shine Protectant on there, now I can't find where I scraped the glue off. Thought its worth a try if the scratches are pretty superficial.
Black Stampede
1,811
Grand Rapids, MI
May 1, 2010
  • May 1, 2010
Prolly a little worse than that.
desertcox05
379
south atlanta
May 1, 2010
  • May 1, 2010
this isn't not the best fix but it's cheaper than replaceing the dash pad.
Mask off around the scratch.
Use some super glue or epoxy to fill the scratch.
Sand filler smooth taking care not to sand the surounding dash.
Paint the filled area with matching interior paint.
While the paint is still wet take a balled up piece of cheese cloth and blot the wet paint to give a textured look.
good luck
whitesqual
235
Coeur D'alene, ID
May 1, 2010
  • May 1, 2010
no bueno!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
May 1, 2010
  • May 1, 2010
good luck
Thats a good idea. Although i would probably fail at filling it in with glue/epoxy
If the scratch is discolored, maybe try painting it to match? If its still an eye sore try filling it in like said above
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • 2000xp8
  • Jul 9, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
