Cannot Get Car To Fire! Distributor Problem??
I just finished putting my car back together and went to fire for the first time and it crank crank cranks but does not fire. I had my dad twist the distributor around while a cranked the engine over and we got it to fire but died in like 10 seconds. I have a feeling I set the the distributor in wrong. Is it different on an sn95 cobra than a fox?
Can anyone help me with a step by step every guide I see is "unbolt hold down, turn tdc, install distributor"
How do I KNOW that it is TDC (I read somewhere on the sn95 it is 10 degree before TDC on install) How do I know it is on the compression stroke... thanks for your help.
  • Disconnect the battery
  • Mark the harmonic balancer at 0 degrees and 10 degrees with white touch up paint or a white grease pen. Each mark is 2 degrees so 10 degrees is 5 marks to the right on the balancer of 0
  • Remove the spark plug from #1
  • Remove the distributor cap
  • Place your finger or a small piece of cotton ball in the top of the spark plug hole
  • Turn the motor over by hand clockwise- never counterclockwise
  • you will see the balance and distributor rotor turn
  • when the pressure starts to build on #1 it will push out your finger or the cotton ball. The rotor in the distributor should be pointing at the #1 location
  • continue to rotate the balancer until the 0 degree mark lines up with the timing tab on the timing cover
  • If the rotor is not lined up to #1 pull it up and reinstall it so the rotor is pointed at #1. You may have to initially position it a little to the left as the gear is offset so when you drop it it will align. Don't worry if it is off 1 tooth as there is no thing
  • Put the distributor cap and battery terminal back on
  • snug up the distributor hold down but not tight
  • hook up a timing light- inductive pickup on #1 wire with it pointing in the right direction and + and - to battery.
  • Remove the spout connector from the test plug by the distributor- Put it in your pocket
  • Align the timing tab on the timing cover to 10 degrees before top center on the balancer- the white mark on the balancer before the white mark for 0 degrees.
  • once you obtain 10 degrees hold the distributor and tighten down the hold down bolt.
  • turn the car off
  • replace the spout connector
  • test drive
so when everything is all aligned would the little prong thing that spins underneath the distributor be perfectly under the #1 spark plug wire? my issue was that I had pulled the distributor out and didn't mark anything. (Generally where does the little prong normally point to when you are tdc?)
So I went ahead and re stabbed the distributor and lined prong that spins with the distributor cap on spark plug 1... so I go to start and i just hear a loud Click and when I turn the key back and then try to start again none of the lights on dash come on until I disconnect and reconnect battery. It was cranking just fine before.. now what..
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
attachment.php
100 mV Ground
0.0V Connections
attachment.php
attachment.php
attachment.php
it ended up being a ground. now its cranking but wont start.. i think there is no spark!!
