Can't figure this out...Please help on vibration
hollywoodstang
1,095
:nonono: Alright I just changed my old worn out parts such as engine mounts, trans mounts, pulleys, harmonic balancer, thinking this will sove the problem. after all this i still can't solve the vibration problem coming from my car....WTF???
It started out of no where and i thought it was either engine mounts/trans mount or harmonic balancer.....even fearking pulleys was pulled and reinstalled!:bang:
What do you guys think it is??? should i pull out the driveshaft? check the u-joint, check the bearing retainer??? when i installed the driveshaft i didn't change those...or it might be a rear end??? i have auburn posi rear with 4:10's
Or might be my flywheel? I have no freaking idea....HELP HELP HELP it is annoying!
Any thought would help. Thanks guys:hail2:
balance the driveshaft....? i don't have that much horse to bend the driveshaft but balancing the driveshaft should help....? what is the step to do this? I have never done this before.
Thanks
