Hope you can help .... I have just rebuilt the engine on my 65 fastback (289) together with a new flywheel and all new clutch parts, now I am not able to select any gears even with the clutch at full adjustment. The clutch arm is moving ok and the thing is the car will start and run with second or third gear selected and clutch depressed .... but it makes a sort of dragging noise in the gearbox. When I then let the clutch in, the car stalls at about half pedal as if the clutch is staring to bite. A pal of mine suggested that the disc may be in the wrong way round, but I checked when the original one came out and it would only go in one way as it would snag the flywheel bolts if it was wrong. The only difference is that the old clutch was a spring type cover plate and the new one is a diaphragm type.
Any suggestions?? or is it time to pull the engine again to check?? How can I tell if the disc is in the correct way round if it is a different type and look to the one that came out??
Last time I had that happen it was the clutch plate hanging up on the inside of the pressure plate[clutch cover] .
