OK, I just installed the Maximum Motorsports clutch quadrant and firewall adjuster. I used a new Ford nonadjustable cable. Installation went smooth, much easier than I expected. The problem is I can't get it adjusted. The clutch won't engage at all. I tried it with the adjuster screwed all the way in, and with it screwed all the way out. The car is up on ramps and I can't get it to move. The clutch has 190,000 miles on it, but is not slipping at all. It was working fine with the factory quadrant. I thought it was about to go because one day it would shift fine and the next day it was hard to shift, then it would go back to being fine. Is there not as much adjustment in the MM unit as in the factory one? Am I going to have to just go ahead and replace the clutch?
