  • 1994 - 1995 Specific Tech
cant get distributor out
  • Thread starter Thread starter urban96
  • Start date Start date Oct 14, 2004
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Oct 14, 2004
  • Oct 14, 2004
as the title says i cant et the damn thing out. everything was going along smoothly for my cobra intake install untill i hit this snag. the little bolt seems to be rusted on there pretty good and i cant get it to budge. anyone have any tips on how to get this thing out?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 14, 2004
  • Oct 14, 2004
Soak it in WD40 or PB blaster for a few minutes then lightly tap on the head bolt then put your wrench on it and use a hammer to try and tap it loose.
urban96
3,464
Syracuse, NY
Oct 14, 2004
  • Oct 14, 2004
ill give that a try, its been soaking for about 30mins so far, i got fustrated and instead of breaking stuff i decided to take a break and post on there
SN95StangMan
1,292
Lynwood, CA
Oct 14, 2004
  • Oct 14, 2004
Just take your time with it. Make sure you mark the distributor before you take it out. When I first tried to install my intake, I couldn't get the damn 50HO plate off the plenum and didn't have my drill with me so I had no way of getting it off.
urban96
3,464
Syracuse, NY
Oct 14, 2004
  • Oct 14, 2004
i finally got it off i also had trouble with the 5.0ho intake plaque. i had the right sized star bits but they still stripped out so i drilled out the heads and poped the cover off that way. i think im gonna polish up the plaque, repaint it and hang it on my wall
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Oct 14, 2004
  • Oct 14, 2004
Yeah, hope you marked it...I didn't, and my car's sitting outside on jackstands after I fought with it all night to get it back running.....grrrr if someone wants to add me to msn messenger to help me out on this one (I won't be working on it till tomorrow morning) I'd really appreciate it
lostcaper@hotmail.com
urban96
3,464
Syracuse, NY
Oct 14, 2004
  • Oct 14, 2004
yeah i marked it, i also taped the rotor in place so it wouldnt move hopefully tomorrow during installation it goes good
TrueBlue95GT
966
Connecticut
Oct 14, 2004
  • Oct 14, 2004
You can get top dead center by taking out the number 1 spark plug, turning the motor until you feel air being pushed out of that cylinder and then turn the motor until the timing pointer is matched up with 0 on the dampner. Then you just drop in the Distributor so that the number one plug will be dead center top and line up the rotor with it. That's it. It should start up and then you can change your timing to a more suitable setting.
xr8d302
Apr 29, 2004
1,113
Medicine Hat, AB
Oct 14, 2004
  • Oct 14, 2004
okay, did this...actually used the pencil method, but either way, cylinder is all the way up.
So I'm doing this how? How am I turning the engine if the distributor's out?
I think this is where my problem is...really I'm just stupid about this, but I wanna learn it, so thanks for the help!
TrueBlue95GT
966
Connecticut
Oct 15, 2004
#10
  • Oct 15, 2004
  • #10
In order to turn the motor, you get a 1/2" drive ratchet and I think it's a 24mm socket and just turn the crank pulley clockwise. Good luck.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
