I have a centerforce II clutch with corresponding disc, this is a 347 stroker crank w/ new pilot bearing,new fork, release bearing, flywheel and pivot ball.
I can get the t5 through the splines of the disk but the rear bearing retainer housing won't seat to the bell housing. Its about 3/16" away from the bellhousing.
I have taken the bell housing off to see how it fits onto the T5 and its ok.
I put the clutch disk onto the input shaft splines ant its good.
I used the alignment tool when I put the clutch on the flywheel. -- Looks good
I don't want to put this engine in the car until I can get this T5 problem figured out, any help will be appreciated.
