  • SN95 4.6L Mustang Tech
Cant seperate tranny from engine
  • Thread starter Thread starter Darkish
  • Start date Start date Dec 21, 2009
D
Darkish
  • Dec 21, 2009
Hey guys,
My throw out bearing went out and I'm in the middle of replacing it, as well as my clutch of course. I'm currently stuck and cannot pry my tranny from my engine. I have remove the five bolts that go to the engine (3 driver side, 2 pass side) and the starter (3 bolts). Seems no matter what i do i cant get it to slide towards the back of the car...
Any help is appreciated
sweet tooth
154
  • Dec 21, 2009
there is a third bolt up top of the trans on pass side too.
D
Darkish
  • Dec 21, 2009
ty for your reply, is there three on each side then? Or am i backwards and i removed three on the pass side and 2 on the driver side?
sweet tooth
154
  • Dec 21, 2009
there is 3 on each side is it a t-45?
sweet tooth
154
  • Dec 21, 2009
there is 3 on each side is it a t-45? the trans could also be stuck on the block pins to.
D
Darkish
  • Dec 21, 2009
no i have a Tremec 3650 =(
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 21, 2009
  • Dec 21, 2009
Check aligment dowels, use penetrating oil
The alignment dowels at 10 o'clock and 2 o'clock can gall making separation difficult. Spray with penetrating oil and wait.
There are two bolts on top that are hard to get to. I have had good luck using a 13mm Flex socket and long extensions.
Remember to support the weight of the engine and the transmission. Don't let the weight rest on the transmission input shaft. It will bind making separation more difficult and possible to damage the transmission/clutch.
Be careful prying too hard on the transmission case. The aluminum is soft/brittle and it can break. Best to work on the whole transmission by hand if possible.
One trick is to leave a couple of bolts in only a few threads. Rock transmission side to side by hand (or foot). If any openings appear, insert something to wedge/hold it open (wood is best). Rock the transmission side to side until an opening appears on the other side. Wedge it open. Repeat until separated to the limits of the last two bolts. The idea is to not attempt too much at a time. You should be able to remove the last bolts and separate by hand.
sweet tooth
154
  • Dec 21, 2009
if it is a 3650 trans should unbolt from bell housing making it easier to take out?
D
Darkish
  • Dec 21, 2009
i wish the bolts are on the inside
D
Darkish
#10
  • Dec 21, 2009
  • #10
ty sweet tooth and wmburns for your help. Im going to try to get it out tomorrow. gl on your tach sweet tooth.
sweet tooth
154
#11
  • Dec 21, 2009
  • #11
ty good luck to.
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • Gulftown980x
  • Jul 29, 2026
squeak93
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
