im trying to unbolt my sensors because i was cleaning off the leaking coolant and i couldnt unbolt the sensors. i tried turning the hex nut and both wouldnt budge. am i missing something here?
They are held in with loctite, so they are going to be a lil hard to loosen up. Im assuming you are talking about the "temp sensors" on the crossover, right?
Just use a lil force and they should break loose, not sure if you can use some Liquid Wrench or WD40 there, but its probably worth a shot. Mine came off after a lil effort
