car back-fired then died, wtf?
1992blkGT
523
Beaverton, OR
On my way back from emissions testing (which I failed miserably), the car started doing things it has NEVER done. It would back-fire insanely and then die. It did not do this once, but nearly 6 times on my way home. I would be driving it, the rpms would spike quickly down really low and the car would start to lurch as I gave it gas trying to keep it from dying. Eventually the car would either simply die quietly or would keep back-firing until dying. The back-fires would shoot black smoke out of the back and after dying, the car would be a total pita to start. It sounded as if the plugs were misfiring when I would be cranking on it, but I don't know how that is possible. I drove the car the entire way to DEQ with no problems and drove it the entire day before. The only thing different is that the car sat idling at DEQ for like 20 minutes and the temp started getting pretty high. After every time it died I eventually could get the car started if I let it sit long enough, and then it would die within a minute or so after running totally in that short period of time. I'm assuming it is an ignition problem, but any idea what it might be exactly? Like I said, the car has never done anything like this before. It has occassionally died while on the highway in 5th, but would always start up within a few secs. Any ideas would be greatly appreciated!! Thanks.
When it dies & will not restart easily, try this...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
1992blkGT said:
I would be driving it, the rpms would spike quickly down really low and the car would start to lurch as I gave it gas trying to keep it from dying. Eventually the car would either simply die quietly or would keep back-firing until dying...
I would tend to suspect the ignition module on the distributor. They have a tendency to do what you described when they heat up. Then they will cool off and behave until they heat up again. If you backfired through the intake there is a good chance you blew off some of your vacuum lines, so be sure and check those too. Good luck...
:nice: Yep, it sounds like the TFI module.
That sounds like it must be it!! Since all my H/C/I mods I have never gotten the car as hot as it was when all this happened. What can I do to fix it? Should I get a new distributor or ignition or what? Thanks for the advice and hopefully this is the problem as it is a lot easier to fix than a valve sticking open!
That kinda sounds like what happened to me when i was driving an 86 w/ carb'd motor that was pretty freshly built - the problem turned out to be that the distributor gear that was on the MSD distributor (both new) broke the little pin that holds the gear on the shaft. It probably had about 500 miels on it since being put together, and i guess the pin was damaged or just weak. It was running great one minute and then out of the blue was sputtering, barely running and had no power. I tried to get home like that, but once it started, i probably only drove 2 miles before it just died - i guess at that point the pin had sheared off completely. Have you done anything recently that could have affected the timing? If the distributor hold down loosened up, or the timing chain skipped a tooth (unlikely) it could exibit those characteristics.
