Car dies at stoplight
  • Thread starter Thread starter N8Dogg98
  • Start date Start date Jun 9, 2008
N8Dogg98
3,872
238
184
MN
Jun 9, 2008
  • Jun 9, 2008
Hello everyone, hoping you can help me with something. My brother-in-law has a 91 crown vic with the 5.0 V-8. When he got it I helped him change the airfilter, oil, spark plugs, plug wires, and the cap and rotor. It ran fine for a while, but then it began to die when sitting at a stoplight while the car is in drive. I seafomed it with him and also did my best to clean out the IAC valve with sea foam as well. The check engine light comes on at idle, but when the engine is revved or you accellerate from a stop it goes away. Any ideas? I don't know much about this 5.0 stuff, as I am a modular guy. Thanks for the help!!!
skunk21
1,203
Taxachusetts
Jun 9, 2008
  • Jun 9, 2008
first things first check the codes, do a koeo. check for vacuum leaks, egr related stuff, bad pvc, etc. post the codes you get and we walk you through the steps.
N8Dogg98
3,872
238
184
MN
Jun 9, 2008
  • Jun 9, 2008
I don't have a scanner. Is there another way to pull the codes? I know in my last car if you turned the key on and off three times the check engine light would flash in a pattern corresponding to the code number. Any idea why the engine light goes off when accellerating? It seems like if the engine light is on it should stay on. Thanks for the assistance
skunk21
1,203
Taxachusetts
Jun 9, 2008
  • Jun 9, 2008
places like advanced auto parts or autozone will scan for free usaully that I know of. the key method doesn't work on his model I believe. It could be bad or lazy o2 sensors but you really need codes to get any where or you will be shooting in the dark so to speak. find a place to get the codes.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 9, 2008
  • Jun 9, 2008
The code dump proceedure is in the following sticky - all you need is a paper clip or jumper wire.
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes] for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
T
Engine 1992 5.0 Died while running, crank no start, Tach Jumping
  • ty50650
  • May 1, 2024
2K
Fox 5.0 Mustang Tech May 4, 2024
Mindseye007
