Car Dies help
zkillrr
97
Memphis.Tn
I have a friend that has a 70 mustang with a 351clev, has a .600 lift 850 carb, and bla bla bla. The problem is when you drive it for about ten minutes
the car dies but will run all day long in the drive way. Has anyone had a problem like this one. Help please:shrug:
If it is a Duraspark, then consider swapping the Durspark box after checking the 12 volts to it with a voltmeter.
If no Duraspark, then check the points to see if they are mounted down tight & have the right dwell/gap. If the points are OK, then replace the coil & condenser.
