Car dies suddenly
Leeroy697
2,294
Detroit, Michigan
Hey guys my car will start up and idle for 1 to 15 mins then when it wants to it will die. No warning, studdering, anything. Fuel pump is new,newer distributer,and I checked with a noid light to make sure the injectors are ok. What in the heck could be causing this??? It seems to stall faster as the car gets warm. Thanks for the help.
There's no need to guess. Do the above testing (it takes less than 5 minutes) and you will know.
It could also be a bad TFI module or even a coil or fuel pump. Any extra testing will stem from the results of the initial testing.
It's cheaper to diagnose than toss parts.
Good luck.
