Car Dies When I Turn My Lights On?
Gary Stanton
Ok so i tried pulling codes and it was a fail , my instrument cluster with 4 cylinder in was acting up the very same way and since I've done the 5.0 swap i bought a 93 5.0 harness and a 1993 140mph cluster and still the same problem. Even if i turn my left signal on it the car still dies,and the instrument cluster lights don't turn on just the hazard lights, the check engine, and the battery , and the temperature gauges sky rocks , so does the fuel gauge and the rpms jump up to 2 grand when the car is off and also when i pull the positive cable of the battery the interior lights got brighter but the cluster was still acting crazy.
can't tell from your post, but do not ever pull the battery cable off when the car is running. It will damage things like the alternator, computer.,etc.. It sounds as if you have a ground issue. Go back and make sure you have all of the appropriate grounds, that they are all clean and attached, including the ground in the kick panel for the computer. Jrichker has a good writeup on the ground locations but these are some of the more common.
Battery ground to block
Battery to 2ndary post behind battery
2ndary ground post behind battery for computer and other items
ground off firewall to engine for gauges and interior
O2 ground wire off harness to firewall- orange wire.
Computer ground inside passenger kick panel
First off we need to know what year car and dash harness you have. When doing a V8 swap 92-3 harnesses are interchanegable, 86-89 work together, 90 and 91 are one off years and will not work with anything else.
Will the car start assuming no other electronics are on?
first up is to check all the grounds like mentioned before.
Grounds
Revised 28-Oct-2012 to add signal ground description & possible problems if it is bad
Grounds are important to any electrical system, and especially to computer controlled engines. In an automobile, the ground is the return path for power to get back to the alternator and battery.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. The clue to a bad ground here is that the temp gauge goes up as you add electrical load such as heater, lights and A/C.
Any car that has a 3G or high output current alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects. The 3G has a 130 amp capacity, so you wire the power side with 4 gauge wire. It stands to reason that the ground side handles just as much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery , computer, & extra 3G alternator ground wire as described above in paragraph 2. A screwdriver points to the bolt that is the common ground point.
The battery common ground is a 10 gauge pigtail with the computer ground attached to it.
Picture courtesy timewarped1972
Correct negative battery ground cable.
56567d1230679358-positive-negative-battery-cable-questions-86-93-mustang-oem-style-ground-cable.gif
3.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally: it comes off the ground pigtail on the battery ground wire. Due to its proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness.
All the grounds listed in items 1,2 & 3 need to bolt to clean, shiny bare metal. A wire brush or some fine sandpaper is the best thing to use to clean the ground connections.
4.) All the sensors have a common separate signal ground. This includes the TPS, ACT, EGR, BAP, & VSS sensors. This ground is inside the computer and connects pin 46 to pins 40 & 60, which are the main computer grounds. If this internal computer ground gets damaged, you won't be able to dump codes and the car will have idle/stall/ performance problems
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground. It is an orange wire with a ring terminal on it. It is located in the fuel injector wiring harness and comes out under the throttle body. It gets connected to a manifold or bolt on back of the cylinder head.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself. The TFI module ground terminates inside the computer.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. Be sure to have the maximum load on a circuit when testing voltage drops across connections. As current across a defective or weak connection, increases so does the voltage drop. A circuit or connection may check out good with no load or minimal load, but show up bad under maximum load conditions. .
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch
100 mV Ground
0 mV to <50 mV Sensor Connections
0.0V bolt together connections
attachment.php
Extra grounds are like the reserve parachute for a sky diver. If the main one fails, there is always your reserve.
The best plan is to have all the grounds meet at one central spot and connect together there. That eliminates any voltage drops from grounds connected at different places. A voltage drop between the computer ground and the alternator power ground will effectively reduce the voltage available to the computer by the amount of the drop.
i noticed my temp gauge rockets when i turn on the lights with the car off, guess i need to check my grounds! would this produce a false overheat on the gauge?
Grounds
300 mV Switch
100 mV Ground
attachment.php
Commenting to reference for later!
FYI, almost every fox body I've owned had the temp gauge go up when you put the lights on. IMO it is one of the inherent flaws of these cars. The guages all share a common wire for power. Another reason to ditch the stock gauges.
