  • 1994 - 1995 Specific Tech
Car Dying - Changed TFI - What now?
  • Thread starter Thread starter sc mustang
  • Start date Start date Mar 24, 2009
1 of 2 Next Last
sc mustang
42
  • Mar 24, 2009
Just bought 94 GT. 347 stroker.
Brought it 360 miles home without a problem. First day home the car dies when coming to a stop. Absolutely will not start. Has spark. Has fuel pressure. Changed TFI. Started up and drove great for 10 minutes then same thing. Dies when slowing down like someone just turned the ignition off. Won't restart.
Seen other posts similar but TFI seems to solve problem. Didn't in my case? Any experience with this problem because I'm stumped.
toyman
1,944
54
79
Vernon BC
Mar 24, 2009
  • Mar 24, 2009
TFI is not usually a problem with the SN95's. You might want to do a search looking for references to PIP and stator. Seems to be a common fault as you described.
95Vert383AOD
1,133
34
69
New Bedford, MA
Mar 24, 2009
  • Mar 24, 2009
+1 On PIP.
There needs to be a sticky on diagnoseing the PIP/ Stator/ TFI issues.
theres at least 3 threads running related to this right now!!!
One of them was mine i think.
HISSIN50
34
129
Mar 25, 2009
  • Mar 25, 2009
Welcome to the boards!
When it acts up and will not start, if you had spark, it's not the PIP or TFI or coil.
Check your fuel pressure and check for injector pulsing.
Pull codes. Does it have or need a chip/tune to accomodate mods?
Good luck.
sc mustang
42
  • Mar 25, 2009
It does apparently have a Diablosport Revolution Chip. All these extra electronics are killing me.
I will search forums for the other issues - thanks for the help. If I figure it out - I'll post.
Have to say - more than a little dissapointing to have a new car that I haven't been able to drive. Its spent the first 5 days either broke alongside a road or in a parking lot.
The fuel pump does come on just for a minute when ignition is engaged the first time. Should I register fuel pressure on the gauge when the pump primes? Seems I only get it when the starter is turned over
99FiveOh
2,051
20
99
J-Ville, FL
Mar 25, 2009
  • Mar 25, 2009
The PIP sensor is only 25 bucks. And they ALL go out eventually in these cars. I was testing good spark too on mine some of the times it wouldn't start. And then magically it would start and be ok for a little bit.
I say change it! There really isn't too many other things that'll cause this "out of the blue" no start/stalling condition on these cars. If you need help installing the PIP, let us know, someone has a link to a good write up with pics.
BlackVert
5,589
9
98
Bethesda, MD
Mar 25, 2009
  • Mar 25, 2009
usually a PIP or stator issue looks like this ...
when not warmed up, the car starts up and drives normally
then at some point after the car is fully warmed up, it dies for no apparent reason
after letting it sit a while and cool off some, it starts up and drives again
then it may die again after getting hot again
here is what is going on when that is the problem:
over time, the PIP sensor in the distributor can lose its resistance to the heat of the engine. then, when the sensor gets hot enough, it fails. after it fails, when the car sits for a while, it cools off enough to be able to start working again.
replacing the sensor solves the problem, but in order to do that, you either have to have a special press or tool to remove and replace the gear in the distributor. that is why some people opt to simply replace the distributor.
so ... does it sound like you have the PIP problem?
sc mustang
42
  • Mar 25, 2009
Its very close to what you describe. The only difference is that it doesn't start after sitting for a little while. It did start after sitting 2 days (multiple tries in between) - ran for 10 minutes then died again - now its dead in the water again. I let is set for 6 hours last night and it wouldn't start.
I guess its an MSD distributor because it definately has an MSD distributor cap. All the ignition parts look new but I suppose that doesn't necessarily mean much.
BlackVert
5,589
9
98
Bethesda, MD
Mar 25, 2009
  • Mar 25, 2009
hmmm, that doesn't smell too much like a PIP problem to me. 10 minutes is probably not enough time for the underhood temps to get high enough. and it wouldn't start even when cold.
just curious ... do you have one of those MSD multiple spark boxes ... like a MSD 6AL? i have heard that people have had issues with those too, specifically MSD ones, causing weird ignition related problems.
just another thing to check ...
HISSIN50
34
129
Mar 25, 2009
#10
  • Mar 25, 2009
  • #10
MSD cap doesnt equal an MSD distributor. You should show pressure after the prime-out.
99FiveOh
2,051
20
99
J-Ville, FL
Mar 25, 2009
#11
  • Mar 25, 2009
  • #11
To get one thing straight, my car would sit for a couple days and not start as well. FULLY COLD! I would mess with stuff, probe this, unplug and plug that in, etc. then it would finally catch and run. Sometimes mine would go a few days without issues, then all of the sudden... DEAD!
I changed my PIP sensor for the second time and it now runs perfect! No more shutting down out of the blue.
And you can buy MSD dizzy caps and rotors as a kit right from your local auto parts house.
sc mustang
42
#12
  • Mar 25, 2009
  • #12
Car Dying Randomly - Next Steps
It is an MSD distributor (I checked) but there isn't any MSD ignition box.
I guess I have to decide whether to change the PIP or replace the whole distributor so now I have the following additional questions:
First, what does PIP stand for? What does it do? I did do a search on this but couldn't find what I was looking for.
Is the term "dizzy" just short for distributor?
Second, can this truly be done at home if I have a good bench vice? I could use a link because once again I couldn't find a good thread on this using search.
Would you guys just replace the whole distributor?
If so - is there a specific distributor I should be considering?
Here is the setup in the 94 GT
5.7L CHP 347 Stroker Engine
Engine Tuned with Diablosport/Revolution Chip
Pro-M 77mm MAF
Edelbrock 70mm TB
Edelbrock Performer RPM II Intake Manifold
Air Flow Research (AFR) 185 heads
Anderson Ford Motorsports B-21 CAM
Thanks for the help - I'd be toast without it.
toyman
1,944
54
79
Vernon BC
Mar 25, 2009
#13
  • Mar 25, 2009
  • #13
QUOTE=sc mustang;7853450]It is an MSD distributor (I checked) but there isn't any MSD ignition box.
PIP Profile Ignition Pickup
Yes
Sometimes it's just easier to replace the distributor. The PIP (stator) can be replaced at home as some have done. You will need a way to remove and press the gear back onto the distributor shaft.
BlackVert
5,589
9
98
Bethesda, MD
Mar 25, 2009
#14
  • Mar 25, 2009
  • #14
i can't answer all the questions, but i'll answer what i can ...
I'm 99% sure it means Profile Ignition Pickup. It provides a signal to indicate when the crank is in a given position.
yep
that is what i would do
Pro-M 77mm MAF
Edelbrock 70mm TB
sounds dang stout. but is it a 5.7L or a 347? 5.7 liters 351 cubic inches ...
:SNSign:
99FiveOh
2,051
20
99
J-Ville, FL
Mar 25, 2009
#15
  • Mar 25, 2009
  • #15
351's are actually 5.8's sir!
And here's the link to the information on swapping the pip:
How-To: Rebuild Your Distributor and Replace the Stator
sc mustang
42
#16
  • Mar 25, 2009
  • #16
Its a 347 - from a 302. When it runs... its a dream
Guess I'll just get a distributor - Just replace the MSD that is there ? ..... or is there one that anyone would suggest?
BlackVert
5,589
9
98
Bethesda, MD
Mar 25, 2009
#17
  • Mar 25, 2009
  • #17
lol i guess i wouldn't know ... mine is more like 6.7L
just get a msd one and be done with it. 10 minutes to replace it
99FiveOh
2,051
20
99
J-Ville, FL
Mar 26, 2009
#18
  • Mar 26, 2009
  • #18
I'd say go with a stock replacement. I've heard bad things and read about them here and other boards about MSD distributors. May Suddenly Die isn't a nickname given lightly!
sc mustang
42
#19
  • Mar 27, 2009
  • #19
Maybe getting closer
Thanks for all the help on this issue.
Went to local Autozone to check on replacement distributor. Although they didn't have one in stock - they did have the magnetic pickup part for my current MSD distributor (PIP) so we went ahead and bought that and rebuilt the distributor last night. Thanks a million for the link to the distributor rebuild thread - wow did they do a great job on that - it was amazing help.
Before pulling the distributor - I did find that if I pushed on the harness that goes into the distributor - I could make the car start every time. I was pushing right at the rubber boot that goes through the distributor wall. I don't think this was a coincidence because the car hasn't started in 3 days and I made it start 5 times by doing this.
Distributor is back in car but we had to stop last night because of time. I'll have to re-time the engine because I moved the distributor before I got it marked (damn!). I think the previous owner said he had it at 10 degrees. Does that sound like a good setting?
I'll post in the next couple days to ensure anyone having similar problems has a full thread to follow. Hopefully I'll have good news to report.
BlackVert
5,589
9
98
Bethesda, MD
Mar 27, 2009
#20
  • Mar 27, 2009
  • #20
sounds like good news to me
the computer assumes it is at 10* with the SPOUT (SParK OUTput connection) disconnected, so make sure you disconnect the SPOUT before you set the timing. it is a little "squareish" grey plastic thing near the TFI. looks like this
1 of 2 Next Last
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
