Car Dying On Freeway And Power Loss
So i dont know what was going on but the Power Loss and Car dying issure fixed itself. But i still have FP Drop at WOT and a Very Weird 1000-1200 RPM Idle.
Im gonna go ahead and put in the New Walboro Pump and new fuel filter and see if that stops the Drop. If not, looks like all be getting a Kirban FPR Next.
Im saying the car has been idling anywhere between 1000-1200.
One day it will be 1000 and the next 1200.
Its supposed to be 750, but ever since this happened it hasnt been the same at all.
Let's see...fuel pumps usually work or not. Perhaps the small rubber hose in the tank connecting the pump to the hard line has a leak or the clamps are loose.
Fuel filter is a great start.
Perhaps you pressure regulator is bad or needs adjusting if adjustable.
Check all fuel lines for kinks....those lines from the pump to the filter and return line may have broken from their retaining strap and be laying against your exhaust pipe and melted....mine did this.
What about ignition? On both of my 5.0Ls, around 170,000 miles, the Hall effect sensor in the distro got weak and gave hesitations and some herky jerks. I've had the high mileage stock plug wires actually burn through the main coil wire. The burn was hidden under the rubber boot. Of course, the TFI is always a PITA.
Your surging idle may be related, or may not. There is a huge checklist for the idle on this site somewhere....includes stuff like clean the EGR, check TPS voltage, check EGR sensor, clean MAF, clean 10-pins, clean IAC, clean all around the throttle....etc., etc. Usually low dollar stuff, just busy work.
Hope some of these ideas help....
Good luck,
Mike
*PROBLEM FOUND AND FIXED*
As i wrote in an earlier post, the car seemed to only do this in the rain which was very strange. A couple weeks ago i took out my wheel wells for cleaning only to find they are cracked etc, so i left them out until i could find some new ones. Well here in washington is rains alot, and the idiot i am, forgot that i had a bbk FENDERWELL CAI lol. So what was happening was the Air filter was just getting caked in water causing the car to die and everyhting else. So last night i went ahead and took the whole intake setup out, cleaned it, and put it back together with a brand new Air filter mounted straight off the MAF. Also got the new walbro 255 pump in and the car runs great.
Sounds kind of crazy but mine was doing the exact same thing and I had no idea what could do except that it was a fuel problem. Changed the fuel filter and found out there was water in the fuel. I added some dry gas and started getting gas from Sunoco w/ 89 or 93 octane and I never had the problem. You have to watch where you get the gas, with the prices of gas today, I've actually seen some stations with garden hoses in the underground fuel tanks. Sometimes when there's water in the fuel the car will do that.
Very good point. With gas prices rising ,there will be more stations diluting the gas to make a profit. The E85 and other ethanol blends will soak up water like a rag and not separate out like conventional gasoline and water do.
