I finally got all my starting problems fixed and got to drive the car for the first time with my new Trick Flow Twisted Wedge heads, FRPP 1.6 Roller Rockers, Trick Flow Pushrods, Trick Flow Street Heat Intake, and C&L Downpipe to match my C&L 73mm MAF Sensor. The problem is, the car is running horrible. It is very eratic, wont idle at all, it just dies instantly after you put it in neutral, and it backfires pretty often. These are not extremely loud backfires but my friend was driving behind me tonight and he saw flames come out my exhaust every time it backfired. It also has the ocasional intake backfire. I have the fuel pressure set at 42 with the vaccume line off, timing has been moved all around and the higher it is, the better. I have new Autolite 3924 plugs, fairly new wires, and new cap/rotor. The mods are as follows:
Stock 91 5.0 HO Rotating Assembly, Stock Cam, TFS Twisted Wedge Heads, FRPP 1.6 RR's, TFS Street Heat Intake w/1" Phenolic Spacer, TFS Tall Valve Covers, BBK 70MM T/B, C&L 73MM Mass Air Sensor w/ Downpipe, FRPP 24* Injectors, Stock Fuel Pump, MSD Blaster Coil, FRPP 9MM Wires, ASP U/D Pullies, BBK Long Tubes, BBK O/R H Pipe, 2 Chamber Flows, And lots of drivetrain stuff, but that shouldnt matter
I know the stock fuel pump is not helping but I dont think it would make the car run this bad, and I know it should be ok with a stock cam, correct? If anyone has any ideas on what stuff I should check, it would be great. I really need to get it to atleast idel, it is rediculous!
