  • 1994 - 1995 Specific Tech
Car has no power, doesn't rev well and jumpy. Spark issue?
  • Thread starter Thread starter Yellow302
  • Start date Start date Dec 1, 2008
First Prev 2 of 2
Yellow302
789
NJ
Dec 2, 2008
#21
  • Dec 2, 2008
  • #21
Spark plugs were the issue. Fixed
Now new issue, i need the timing pointer that bolts to our block... must have lost mine doing the swap.
Junkyard or can i order one. w/o it i cant set base timing to rule it out.
Yellow302
789
NJ
Dec 3, 2008
#22
  • Dec 3, 2008
  • #22
Now that spark is good, i noticed my MAF voltage is very high... 1.5 volt at idle it used to be around .80.
i havent rotated the maf, it is still straight up and down. but i have added a 3 foot snorkle hose in front of it to stop the turbulent air issue i was having. When i changed the spark plugs the inlet tube droped with the maf connected and may have tugged some wire out. the MAF volage is also very irradic at idel jumping volts at a time.
I am going to re splice the MAF wiring with all new connections.
The day before it rained for the first time, so the MAF may be dirty.
Build a small water deflector for the air filter.
Suggestions welcome.
Yellow302
789
NJ
Dec 3, 2008
#23
  • Dec 3, 2008
  • #23
MAF fixed,
re spliced 4 wires and soaked the **** out of it with MAF cleaner
Now the car takes my tuning and is running stable.
Car still doesn't rev fast enough and doesn't get up and go.
So now i'm down to the following...
1. Spark wires (they should be fine) but i made them myself Mr. Badwrench
2. Cap / rotor? were replaced shortly... like 2 weeks before the engine swap
3. Coil? has been painted, bracket is painted, and bracket to head is painted... so this can be a grounding issue if this does in fact need to be grounded.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 3, 2008
#24
  • Dec 3, 2008
  • #24
1. You should be able to test the spark plug wires by buying a set at your local store and trying them out. Return them if they don't solve the problem.
2. Can't hurt to check for corrosion.
3. I believe these need to be grounded through the block. When I painted my engine, I marked where the brackets were touching and scraped off the paint in between.
Yellow302
789
NJ
Dec 3, 2008
#25
  • Dec 3, 2008
  • #25
define these?
First Prev 2 of 2
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
R
Dead car, please don't ignore
  • RogerMV
  • Apr 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 16, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
