  • SN95 4.6L Mustang Tech
Car idling funky... :(
  • Thread starter Thread starter JonJon
  • Start date Start date Apr 11, 2004
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
I installed a Densecharger tb pipe last Friday. I reset the battery (the gauges pegged after I turned the car on) and then let her idle for 5 minutes. Everything seemed fine. I drove to the drag strip (45 miles away) and about 5 miles from the drag strip I notice that when I came to a stop, the idle would bounce around and when shifting the revs hang. I got to the drag strip and reset my computer again since the car threw a SES... I checked connections to make sure everything was tight and hopefully no leaks and the SES was gone. I ran like crap at the track, no where near what I wanted to run. Not totally unexpected though with the 50 F weather, my driving, and my tires.
Anyways, I recorded 2 vids of the problem. These vid's are WITH the AC on, it wasn't idling funny last nite without the AC on. But today, it IS idling funny even without the AC. I reset the battery again yesterday morning and since, I've driven 60 miles. I recorded the vids after those 60 miles of driving.
You need the DivX decoder, I couldn't get an MPEG file small enough http://www.divx.com
I did NOT touch the gas pedal in either of these vids. The car just bounces around.
Odd idle 765KB
In this vid, I clutch in and the engine REVS up then idles down. I did NOT touch the gas pedal. I was coasting at 1800RPMs then clutched in and the car rev'd up to 2000 by itself. After another second or two it drops down to 700...
Hanging idle 140KB
Any idea's? Will it smooth out?? Another user had said his idle smoothed out after a few days of driving, but I wanted to post vids and get opinions. I figure 60 miles of driving should be enough for the computer to learn the new air flow but I guess not?
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
oh, I'm going to call DeMolet (Densecharger) on Monday and see what they say.
Car idled -perfect- with stock tb pipe. Even though I USED to have slight RPM drop when I came to an idle.
dkshadow
Banned
May 12, 2003
952
TEXAS
Apr 11, 2004
  • Apr 11, 2004
http://forums.stangnet.com/showpost.php?p=4051878&postcount=11
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
Dyno on Saturday... but no tune.
slvrbullIT
635
Dallas, TX
Apr 11, 2004
  • Apr 11, 2004
my tach sucks balls, sometimes when im cruising in 4th @50mph it reads 500rpm and then a minute later it will jump to 2000rpm where its supposed to be. I am getting a tune soon anyways since i still havent had one after my headswap.
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
My friend back home thinks it's a vacuum leak since he had the problem on his Cougar and his brother on his Talon.
Sound about right? It's getting dark now so I'll check tomorrow.
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
No one's had a vacuum leak in a 4.6?
DarkCheshire
10
DC
Apr 12, 2004
  • Apr 12, 2004
Check and clean<----(maybe) your IAC (Idle Air Control) and anything that leads up to your intake. Mine did it a while ago and it was a cross of the cold air intake not being mounted secure enough to the frame and my IAC was a little dirty. So in short the car was thinking it was getting less/more air and was trying to idle to compensate.
20BlackGT02
63
  • Apr 12, 2004
Does anyone know how to get these clips to work? Everytime I play the clips, my PC freezes and I have to restart. I would like to see how your car idles. What you are explaining sounds like the same thing that happens to my car since day one for the rpms to hang between gear shifts. I thought this was normal. And after both of my heads were replaced under warranty, the odd AC idle thing started to happen. When ever the AC kicks on for the defrost or air conditioner, the idle jumps up a hundred or two hundred rpms. I dont think this is normal. If it is, it's annoying.
JonJon
4,801
back in Marylands
Apr 12, 2004
#10
  • Apr 12, 2004
  • #10
All I changed was the tb pipe though, the car was running and idling -perfect- with the stock pipe. Would that affect the IAC? Plus, the IAC was replaced this past summer... I just checked the MAF wires when I was checking for a vacuum leak, the MAF wires looked clean. The IAT sensor was aligned correctly and everything too.
Sorry, I don't mean to crash your computer. The people I've sent the clips to have had no problem... It requires the DivX 5 codec from http://www.divx.com but it shouldn't cause crashes if you don't have it installed...
When I checked for a vacuum leak (I unplugged everything and replugged it all real tight) I let it run and it still idled funky... So I changed the idle screw a little (wider) and it seemed to have helped... My car is idling at 800rpms now (digital built in tac) and sometimes hangs at 1000 but so far it isn't doing that wild idle. I only got to drive it around for half an hour earlier so I don't know if the problem is going to come back again. I'm going to go drive around more tonight. I'll also try to turn the idle screw down a little so it doens't idle at 800...
rd02gt
123
Brea, CA
Apr 12, 2004
#11
  • Apr 12, 2004
  • #11
my car idles at 500 rpms and is real boggy off take off, any idea?
20BlackGT02
63
#12
  • Apr 12, 2004
  • #12
I got the vids to work. My work laptop is a piece of sh@t.
The first vid is crazy. Mine's not that bad. 700 rpms without the AC compressor on and 900 rpms while the AC compressor is running.
The second vid is exactly what my car does. I just thought that was normal or there was a delay in the gas pedal since there is soo much slack in the pedal cable while I was letting off the gas and pushing the clutch in.
00gtconv
516
#13
  • Apr 12, 2004
  • #13
change pipe
I would change back to the old pipe and see if you still have the problem.
I have a feeling it will still act up with the old pipe; somthing may have gotten moved or is not connected right. Start there!
If it runs fine with the old pipe then you know what the problem is!
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
