Car Intermittently dies when I take it out of gear
Timin
207
Houston
Hey All,
I have a 98 GT 5spd that I don't put many miles on at this time, and it has been experiencing this issue for the better part of the past 3 years or so. Basically, I can be cruising around (usually under 50MPH) and if I take the car out of gear and put it in neutral the RPM's will not bottom out at the normal idle range(675-750 rpm,) and it will just keep going lower and the car will die. I can prevent this from happening if I tap the gas right as I pull it out of gear; the car will idly normally every time I do this. There are no other idling issues at any time while cranking the car cold, idling at lights, etc.. I had to replace the IAC many years ago and if I remember correctly the RPM's would hang around 1200 even when the car was stopped, so the symptoms seem a bit different.
We replaced the plugs and wires at 90k miles (NGT TR55's,) and I had the unfortunate luxury of the #8 cylinder shooting the plug out within a few months. We ended up tapping and rethreading the existing head; I had a mechanic do this so I am not precisely sure on the current details of the plug in that cylinder (Size/Temp.) I set the timing back to the factory level 10 on the T/A, and I recently ran Sea Foam through the engine for the very first time. Neither of these have had any impact on this. I have not cleaned the MAF recently (not sure of the last time I did,) and I think this is something i'll take care of here this week. One last thing to note, when I look at my 2 Chambers it appears that I bought them with some piping already welded on to the muffler; this piping appears to be 2 1/4 or even 2 inch pipe. So the exhaust does bottle down some before it gets to the actual muffler, not sure if backpressure or anything else related could be a culprit?
Mod details and other information:
150,000 miles on the car
MAC Long Tube Headers
2.5 inch VRS High Flow X Pipe
2 chamber Flowmasters
Steeda Pullies/Timing Adjuster
Thanks for any thoughts on this:
-Karl
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
B car dies intermittently, advice on what I've found Fox 5.0 Mustang Tech 3
Yellow302 Electrical Intermittent Battery Charging / Car Not Charging 1994 - 1995 Specific Tech 4
BigHairyMonkey Car intermittently runs lean Fox 5.0 Mustang Tech 1
JTGrant Intermittent knock from engine underneath car 2005 - 2009 Specific Tech 9
M Engine car cuts out without revs Fox 5.0 Mustang Tech 3
R Engine Car has no power under acceleration, but has no codes 1994 - 1995 Specific Tech 3
T HELP MY CAR IS RUNNING TERRIBLY! 1996 - 2004 SN95 Mustang -General/Talk- 1
E Any way to tell if my car is modified? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 64
A Electrical Help. I’ve about had it with this car.... Fox 5.0 Mustang Tech 12
silverlx50 Engine Car spewing fuel Fox 5.0 Mustang Tech 27
7 Progress Thread Oregon Pace Car Story to Coolness 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
7 New Guy from Oregon 79 Pace Car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
A Car starts but dies Fox 5.0 Mustang Tech 2
93silverlx50 Engine Car in limp mode, fuel spitting out of tailpipes, missing rough idle Fox 5.0 Mustang Tech 9
T Decent deal on these cars? Or keep looking? 2010 - 2014 Specific Tech 4
R New car! 2015+ (S550) Mustang -General/Talk 2
CrazyRedFox Fuel Noise from the rear after shutting off car Fox 5.0 Mustang Tech 7
slayr281 Hey, I know that car! 2015+ (S550) Mustang -General/Talk 0
M For Sale FS: 2000 Mustang GT Track Car / 62k Miles / 5k on Motor / Full Roll Cage / California / $5,000 OBO SN95 Mustangs For Sale (1994-04) 0
Olivethefet Drivetrain One Man T5 Tailshaft Housing Install In The Car Fox 5.0 Mustang Tech 6
R Fox 1987 Charcoal Canister Test - Test off car 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
trlps_ Need help, car wont rev up or drive 1996 - 2004 SN95 Mustang -General/Talk- 2
S Strange sound coming from under car? 2001 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 1
Gtbabydriver new to this site and learning about my car 2005 - 2014 S-197 Mustang -General/Talk- 2
T Car Stalling OUT 2005 - 2009 Specific Tech 1
P Progress Thread My First Project Car And My First Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
Wayne Waldrep Engine Trouble with the old pile...I mean car. Need some help. Fox 5.0 Mustang Tech 7
D How to know if car springs are bad on just shocks? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Mixveez First car 86 T-Top 4 eye Fox 5.0 Mustang Tech 67
L Raising the car for Subframe connector welding (or other reasons). 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
J Start a car club in Lancaster/Palmdalr area Regional Forums and Event Information 0
T Fox Scored a 5 speed feature car with only 67k original miles 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
V A 20 year old car, with many faults! SN95 4.6L Mustang Tech 7
DarkFox I'm a new stangnet member and I am removing the :poo:ty early 90's alarm system in my car. Northeast Ohio failure here. The Welcome Wagon 21
R Car wont start 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
L 1997 Cobra Tune Question (and some background on the car) SN95 4.6L Mustang Tech 3
91GTstroked Engine Gas smell in cabin, car died on highway. Fox 5.0 Mustang Tech 19
5 Electrical Tick when connecting negative terminal to battery. Tick no longer happens but car doesn't start Fox 5.0 Mustang Tech 7
0 Plenty Fuel, No Spark. Car will not start 1996 - 2004 SN95 Mustang -General/Talk- 5
S Electrical Speed Density 02 Harness on Mass air car?? Fox 5.0 Mustang Tech 18
G mustang running rough after car wash 1996 - 2004 SN95 Mustang -General/Talk- 10
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
Jason Roberts O2 Simulators put on a 1994 GT 5.0 do they hurt the car or are they useful even though the 94 GT only had 2 O2 sensors and they were before the cats 1994 - 1995 Specific Tech 3
W Progress Thread Car runs poorly over 4500rpm 1994 - 1995 Specific Tech 13
T_Roberts 2 10'' Subs in trunk rattle underneath car SN95 V6 Mustang Tech 8
rabidscoobie Car stumbles at higher RPM's? SN95 4.6L Mustang Tech 12
91GTstroked Engine Mounting map sensor in car? Fox 5.0 Mustang Tech 7
revhead347 Buying Car Parts is somewhat pleasant now 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
