Car is stumbling
Does anyone know why my car kind of bogs down when I step on the gas pedal too far? It never was this bad but it used to do it only when I floored it too far to the floor. But now it does it when I come off of a stop sign and it seems like the car gets overwhelmed and bogs it self down. Or when I am going down the road and I have to kind of ease into the pedal to go fast. I have new plugs and wires, all motorcraft and the cap and rotor isn’t that old and that is Borg Warner. I was wondering if it could be my computer because it has a dent in it from a previous wreck but it still throws codes. I have the stock PJ computer and I am also going to put in the La3 when I get the chance. Or could it be fuel related. I have the stock SVO pumps on the car. What are those rated at? (lph) Would it be possible to get a 255lph pump and delete the frame mounted one and just have one in tank pump to control everything if it turned out to be fuel related? Thanks for any ideas
SVOconvLX85 said:
But it only does it when I mash on the pedal. It doesn't do it when I gradually increase the throttle
Have you ran a "Key on" "Key off" code check? If so what codes are you getting?
Have you checked for vaccum leaks? dumb question I know but that is what always gets me :D
By chance are you using green top injectors?
No my SVO came with the brown tops and one of those was shooting a jet stream out while the others were doing the right thing, so I got some of those Tomco flat top black 35 pounders. They say they are usually the replacements for the stock injectors and my car idles fine since I changed the injectors. It has never idled that great since I fixed the problem
So you saying when you bought this car new it came with a set of brown top 35lb injectors with a PJ EEC thats not calibrated for them :scratch: Why didn't you take it back to the dealer and ask for the correct injector size :shrug:
