Well I finally got my head gaskets replaced and my cams installed. The only problem is the car idles a little high and I have a surging problem. To start off after I got the car all back together after the install the car fired right up. I revved the motor for 10-15 min between 1500 and 3000 rpm,s to get oil to the cams. After that I let the car idle for about 10 minues- here it idled at 900rpm and sounded AWESOME!
The second time starting it up it wouldnt start. I tried a couple things and then finally gave it some gas and it would turn over, only now it was idleing at 1200rpm! I took the car for a drive and when I pulled up to the first stop sign, as soon as I pushed in the clutch, the car shot up to 2000rpms! And it doesnt drop untill I sit there for about 5-8 seconds. VERY annoying.
Here is what I have tested so far:
1. cant find any vacuum leaks
2. Passanger side 02 sensor got burned up, fixed the wiring
3. Cannot get a reading from bank 2 02 sensor with the xcal2 dataloger
4. Blown #8 fuse under the dash for engine control
5. Cleaned IAC housing
6. Unhooked the battery after every step
7. NO trouble codes
After all of this the car idles at a stand still a little better and doesnt die, but it still surges. The tune is from MPH and the cam install was done perfectly, everything degreed perfectly. Where do I go from here? Im thinking about just taking it to the dealership and saying FIX IT!!!
Thanks for any and all suggestions, thanks!
7. NO trouble codes
