- Aug 13, 2007
- 5
- 0
- 0
Hey! new to the forum here. have a problem with my 87 LX that i cant seem to fix. i bought this car a few months ago. this mustang sat for almost 2 years, being driven only a handfull of times within that period. It was driven about 200 miles from PA to MD right before i purchased it. It makes it here and now doesnt run properly. the problem i seem to be having......it will start and idle a bit rough at first but evens out. after that, it will idle forever, but when i start to drive it down the road it doesnt make it far. It just falls on its face and dies. the car doesnt want to turn over like the battery is dead ( real slow crank). by the third try it turns over ok but does not start. if it sits for about 15 mins it will finally start. i used to have to keep my foot in the gas to keep it from dieing until i make it home. last time it died on me the inside of the car smelled of sulfur, leading me to believe the cats are bad. i have since changed the fuel pump/filter, cap/rotor, coil, starter relay by the coil, battery, tps sensor and adjusted to .98V, cleaned out the t-body and AIC, changed a few vaccum lines, new wires/plugs, changed the oil, and kind of ruled out the alternator. the car only has a few mods ( LT headers and 3.73 gear). The cats are fairly new and are magnaflows, but they will be gone within the next few days when i put on an entire new exhaust on. anyone else suspect the catalytic converters or maybe the o2 sensors? any other ideas???? any help would be appreciated!
