car lost all power today!!!!!!!!!!!!!!!!!!!11
fourmustangs
92
Houston
I just did emissions testing on a 87 5.0 last month.
just the other day my cat starts to rattle and I think the other one is probably blocked. if these were going bad why would I pass emissions with flying colors?
it started rattling and today lost all its balls.
the cats are only a year and a half old
only have two on H-pipe no pre-cats
on gtech last month it was 16 sec 1/4 with 2.73 and I spun in some water on the road. I recently put 3.55 with my aod and spun just a little andhad almost same time
kind of depressing
just put msd coil and fuel regulator on just before cats totally went bad???
:nonono: :nonono: :nonono: :nonono: :nonono: :nonono: :nonono:
A vacuum gauge along with a Chilton's shop manual will give the how to test for clogged cat converters.
Once you have eliminated the possiblity of clogged cats, then dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
You lost me. Are you saying that the car is slower now, per an inertia meter, and clogged cats? How does it run with the cats removed or a new pipe on there?
Clogged cats will wipe out performance if they are bad, as well as allow you to roast hot dogs in the back seat.
Good luck.
