car makes a whining sound
  • Thread starter Thread starter bleeatch
  • Start date Start date Mar 28, 2004
bleeatch
43
phoenix
Mar 28, 2004
  • Mar 28, 2004
recently my car has been producing a whining sound that gets louder with the RPMs like its supercharged or something. It sounds like its comming from the water pump. Do they do this when they are goin bad? When i got my car it didn't have a tensioner pulley and i just put one on, then 2 days later the sound starts up. any ideas?
-Allan
C
charlesw6954
476
Mo
Mar 28, 2004
  • Mar 28, 2004
are you sure its coming from the water pump? i had a whining noise once and it came from my transmission. my noise also sounded like it came from the engine, but didnt.
bleeatch
43
phoenix
Mar 28, 2004
  • Mar 28, 2004
well i went back and listened again from all sides of the car trying to see if i could hear it from the tranny but it definitely sounds like it comming from up front. I listened all under the hood and it still sounded like it was comming from the the water pump, maybe the alternator. maybe its a bad ground from the alternator? would that make a whine?
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Mar 28, 2004
  • Mar 28, 2004
take the belt off and wiggle the fan blade see if it feels loose. also when belt is off start car and see if the sound is gone.
bleeatch
43
phoenix
Mar 28, 2004
  • Mar 28, 2004
i took the belt off and the fan isn't loose at all, i didnt want to start it with the belt off cause its a serpentine, probably should have specified that my car is a 89 GT. Once thing that i did notice is that the way the previous owner routed the belt when there was no tensioner has the water pump pulley spinning the oppisite way as it is now. thats the only pulley that is now rotating the oppiste was as it was before. can this make it go bad?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Mar 28, 2004
  • Mar 28, 2004
it wont hurt to start it with no belt. And you must have the water pump spinning backwards MEANING: when your standing in front of the car looking at motor the water pump turns Counter clock wise. Is this the way it was before?
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Mar 28, 2004
  • Mar 28, 2004
  • brandyn200
  • Jun 20, 2026
AeroCoupe
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
D
Engine Serpentine belt squeal after reinstall?
  • dqureshi06
  • Oct 30, 2024
Fox 5.0 Mustang Tech Nov 1, 2024
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
