Car never gets past 130*, even when hammering
astronut1885
1,899
Assonet, MA
Hey guys. I've noticed lately that my car's temp won't get hot. When I start it, it takes about ten minutes to rise to about 130*, and then it doesn't move. I can do runs on a back road, high rpms on the highway, you name it, and it won't get hot at all. I am thinking about getting an aftermarket gauge setup, but is there any way this could be accurate on the stocker?
Stockers are far from accurate.
Try changing your thermostat.
Sounds like maybe your thermostat is stuck 'open'.
you can check your t stat by squeezing the top hose when hot. also, take the rad cap off and warm it up. watch coolant flow from pass side to drivers side in the rad.
the stocker can be that far off. thats what mine reads when its winter time (tucson, still high of 75*). that is with new sender. the stocker reads ~40* cooler than my aftermarket gauge. then it will sometimes catch up.
aftermarket gauge is a necessity for stangs, IMHO. id do it and then if it is something else, replace it then. atleast you will be better equipped to troubleshoot it. i bet its the gauge.
good luck.
the new tstat is going in with the new lower intake, and I am going to install a set of Summit gauges at that time too (voltimiter, oil pressure, and temp). Glad to know I am not the only one with a crappy gauge. Odds are the original factory tstat is in there, as the previous owners didn't know crap about cars and maintainence.
I debated for a while about getting aftermarket gauges. HISSIN50 finally sold me on getting the some time back when I was having oil pressure issues. After installing the new gauges I will say that is one of the best things I have ever done to the car. The stockers are very crappy. I run a 180* stat beacuse of the heat and humidity here in the summer time and with the stocker it just wondered all over the place. My auotmeter sets right on 180* unless I hammer on the car. If I ever buy another 5.0 I will buy a set of gauges before any other mod.
The Shape, thanks. glad i give decent advice every now and then. :-)
ah, no one asked: what ambient temps are you seeing? does you heater kick out decent heat? im thinking with a stuck open stat, the heat would suck. above tests i mention help rule that out or confirm it. i really like the Mr. Gasket thermostats. they open fully sooner than parts store variety, are balanced, have bleed hole (saves you drilling you own) and only cost a few bucks more than the cheap generics.
69 boss, if doing an SN95 is anything like a fox, it is easy and hard. :-) i found it to be a pain, as the driver side bolt comes out at like 1/84 of a turn at a time on mine. ten minutes later, its out. the pass side bolt is easy. then finagling the small hose off of it is a pain if the hose is old and doesnt come off. really not bad, just tedious. but takes 10-15 mins to do. two bolts, two hoses and out. dont overtighten the bolts, as housings like to crack.
to me, that suggests that your stat is at least partially functioning, and that the gauge is screwy. mine will read a lil' over 130 when im at 180-ish sometimes. i have to breach 195 or so to make it go higher.
One of those ratcheting box end wrenches would come in handy for the drivers side housing bolt I would think. I have an old 1/2'' wrench that I bent in a vise that makes it a bit easier to remove that bolt. And HISSIN50 is right that bypass hose can be a real pain.
