Car performance/stock intake
  • Thread starter Thread starter Brett88lx
  • Start date Start date Nov 6, 2006
1 of 2 Next Last
Brett88lx
65
  • Nov 6, 2006
Recently, I finished puting my car back together. It starts up just fine, runs pretty smooth, and even goes pretty good.
But I was just wondering how much slower is the stock intake making my car. The engine specs are listed in my sig. How much faster would my car be if I swapped the stock intake for the GT40? Would it make a NOTICABLE differance in the cars overrall performance?
Thanks in advance for any feedback.
8950HO
658
  • Nov 6, 2006
The stock lower intake is a restriction even with the crappy E7 heads and even more with your GT40P`s.
You would likely gain a significant increase with a better intake like the GT40.
Right now you have a major bottleneck with the stock intake.
Sicarius428
2,085
Nov 6, 2006
  • Nov 6, 2006
They are a huge bottleneck. Check out a member here called tmoss. www.tmossporting.com he can really open up your stock intake.
Kevin
V
v8only
2,378
22
49
Nov 6, 2006
  • Nov 6, 2006
put it this way, I'm running a ported stock intake on gt40p's, (ported 60mm throttle body) and my bro is running the gt40 explorer intake on his gt40's with a 65mm throttle body. The difference is night and day. To be fair, he's got a tfs 1 cam, I've got an ho oem cam, however, the difference is so night and day, it's obviously my intake/tb setup. He's likely a second if not a second and a half faster by seat of the pants feel.
You should notice a respectable gain by ditching that oem intake. My explorer/gt40 intake and 65 mm tb are going on next weekend, and I can't freeking wait.
aod92
104
  • Nov 6, 2006
I wouldn't bother porting the stock intake. You mite as well just buy a newer better flowing intake for the money
V
v8only
2,378
22
49
Nov 6, 2006
  • Nov 6, 2006
agreed, i've got a fully ported lower (friend ported) however, with the gt40p heads, and that upper, it's just not worth it.
Brett88lx
65
  • Nov 6, 2006
Thanks guys. I really appreciate your advice. You told me what I wanted to hear. I'm probably getting a deal with my friend for his GT40 intake(with plastic shroud) and 70mm TB for $300. This would go well my my 73mm mass air and B cam. Thanks again.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Nov 6, 2006
  • Nov 6, 2006
They are a big restriction yes, but when i put an explorer intake on my car, i didnt feel much, I know it breaths better but you probably wont feel a difference, im sure youll notice a difference at the track, I went from a 13.5 to a 13.3
FSTRDNU
76
  • Nov 6, 2006
you go to a decnet intake, tb, expect to pickup 30 hp no problem
V
v8only
2,378
22
49
Nov 6, 2006
#10
  • Nov 6, 2006
  • #10
a 70mm throttle body is too much for gt40p heads, stick with the 65
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 7, 2006
#11
  • Nov 7, 2006
  • #11
From going to a GT40/65mm from a stock intake/60mm ??????????????
Ported stock intakes are documented to make 280+RWHP on portred E7 or GT40 heads no problem with the right combination of parts that include a custome cam and ~260RWHP on mild cams. They will produce more average torque in the low-mid range than the GT40 style intakes - but averages will be VERY close over the whole usable idle-5,500 rpm range. They will both work very well for you.
ls1beater4eva
334
mooresville
Nov 7, 2006
#12
  • Nov 7, 2006
  • #12
i would check around and see if you couldnt find a holley systemax intake it was a night and day difference when i put it on.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 7, 2006
#13
  • Nov 7, 2006
  • #13
The Holley SMII is not the best choice for you - it's too big for best average power.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Nov 7, 2006
#14
  • Nov 7, 2006
  • #14
Gt40 and 65mm would be a decent SOTP change but not 30hp as stated.
Brett88lx
65
#15
  • Nov 7, 2006
  • #15
Thanks again people. I really appreciate your advice.
modusmortis
54
#16
  • Nov 7, 2006
  • #16
I would highly recommend checking out tmoss's site. It has ALOT of good information on it with some great dyno charts, and it really shows you where you can take your stock intake. If you're not planning on porting your gt40p's I would recommend the ported stocker for the best combination of low end torque and higher rpm horsepower. If you're planning on upgrading/porting later I would suggest going with the gt40/cobra/explorer intakes.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Nov 7, 2006
#17
  • Nov 7, 2006
  • #17
T-Moss does good work.My 93 went 13.8 w/ his ported intake,the rest was all stock cept for bolt ons. But with your set up you would benefit greatly from a GT-40 or even a Cobra would do the trick,and is alot cheaper. T-Moss also ports Explorer intakes which compare to the cobra. Go to his web site and see the results.
FSTRDNU
76
#18
  • Nov 14, 2006
  • #18
for $600+ dollars he better see +20 hp at the tires.
wich is somewhere in the vacinity of 30hp
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Nov 14, 2006
#19
  • Nov 14, 2006
  • #19
A Cobra is under 400. A ported Explorer is around the same if not cheaper.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Nov 14, 2006
#20
  • Nov 14, 2006
  • #20
I got an Explorer complete engine for 350
1 of 2 Next Last
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
