Car runnin like crap/comp related
fox04
78
augusta, ga
Ok my car is a 88 gt 5spd A9L computer code. well this mornin i went to crank my car up and would only turn ike it wasnt gettin fire. I waited a couple minutes an tried again an crunk right up. The car ran like crap. Kinda sounds like a car that has a blown head gasket and has low power. So i took it home pulled the plugs they looked like crap so replace em an car had same prob. I pulled the msd box to see if maybe that was it. Didnt fix it. So i checked evrything i could think of and pulled the computer out. It has a sct eliminator tune on it so i unpluged the chip and the car ran perfect but not like it does with the tune. I plugged the chip back up and car wouldnt crank. then i waited a few minutes with the chip still plugged in and the car ran great. I went to leave again and car ran like crap. I messed with the comp a little more and ran great all night till my way home i did the same thing. The person b4 me did the mass air swap on it so could it maybe tht idk what to do im lost and highly annoyed at this point
Please list you mods so we can get an idea of what is in the engine.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 18-Mar-2011 to advise differences in code information for engine running and engine off codes.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
What color are the injectors?
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
http://www.veryuseful.com/mustang/tech/engine/i
