car running horrible
ban-one
59
ny
i started my 00 gt today and it was running horrible check engine light is on and blinking and its running on 5 cylinders had codes read and the evac code for small leak in fuel return system and the p0302 and 0305 for cylinder 2 and 5 misfire
it runs rough through the rpm band what could of caused this. as soon as i hit gas the check engine light blinks? any ideas
An EVAP (as in evaporative emissions) code isnt going to be the cause for a misfire on 2 cylinders. If you meant the code is for a leak in the fuel system perhaps you should check that out; check fuel pressure if you can.
And as stated above inspect your coils it wont take long.
