Car running like crap help!
  • Thread starter Thread starter Nottoofast50
  • Start date Start date Jul 31, 2004
N
Nottoofast50
386
Cali
Jul 31, 2004
  • Jul 31, 2004
I was trying to adjust my fp the other day(kirban afpr). My gauge shows 30psi at idle with vacuum connected or disconnected. So i unplugged the vacuum and turned the screw. The gauge didn't move. I turned it probably 6-7 turns and the gauge still didn't move. I figured the afpr was broken. I also just got a 77 pro-m in the mail. I tried to put that on after doing the fuel pressure and the car will not even make it around the block without dying... and the check engine light goes off. So i put the C&L back on, it will run fine but is way way down on power won't even spin the tires in first. My fuel pressure gauge is still showing 30psi, I am thinking maybe the fuel pressure gauge is broken? It goes to 0 when i turn the car off. Or is the kirban probably broken? Also i didn't reset the computer between changing the mafs, could that be the problem? Help!
N
Nottoofast50
386
Cali
Jul 31, 2004
  • Jul 31, 2004
Should I have reset the computer after installing the pro-m? Would that have made a difference?
M
Mhypertext
30
Joplin MO
Aug 1, 2004
  • Aug 1, 2004
real easy
dont mess with the fuel pressure leave the stock one on
the adjustables are crap
a friend of mine runs low 11s with a stock one
D
dude5l
201
Grande Prairie, Alberta , Canada
Aug 1, 2004
  • Aug 1, 2004
I've seen that problem before. Your pump is weak.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Saturday at 9:49 AM
CAMTWO1070
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
