ok i've kind of had an ongoing problem with my car and im sick of it. some things have helped, but nothing substancial or consistant.
my car seriously lacks lowend, and it isint revving like it should in the upper rpm's even. first gear doesnt even snap anymore, i tap the pedal like i used to and it almost hesitates for a second, then slowly revs. first gear floored rev's like third should.
i have all the mods in my sig. i pulled my codes, and im getting 3 that are worth questioning. 2 are from smog pump that is disconnected
23- Throttle Position sensor signal out of range.
how do i adjust that on an 88? i have a chilton for an 89+, and it tells you how to measure volts, ect.. but it is a different setup on my 88.
67- Neutral drive switch circuit failure, circuit open.
lastly, 95- Fuel pump secondary circuit fault.
has anyone had these codes/issues before? would the TPS completely throw off my lowend power and revving as bad as im experiencing?
thanks for any help. would like to get this fixed before i install my new heads.
