Car runs like crap when its hot outside and it generally ruuns wierd all the time. It kinda lags starting out in the RPM's until it get's going and then it does pretty well, but its always a bit sluggish. I have replaced all within the last month..The fuel filter, fuel pump, fuel pressure regulator, Coolant temp sensor, spark plugs, spark plug wires, 02 sensors, cleaned MAF sensor, Cleaned ACT sensor, cleaned and oiled K&N air filter, adjusted timing to 10 degrees-(anything above that and it pings), and i even ran a can of sea foam through it yet to no avail. What else could i do?
