  • 1994 - 1995 Specific Tech
Car Runs Like ****!!!!!!!
  • Thread starter Thread starter Guero
  • Start date Start date Jun 5, 2007
1 of 2 Next Last
Guero
2,148
Jun 5, 2007
  • Jun 5, 2007
Well Today, I got the pioneer balancer put on. So I clean the air filtr re-oil it, put new engine oil, re-set the timing. Took it out for a spin and it ran like ****. It sputters while trying to get speed normal driving, has no balls. It does idle better for some reason. I know its a 10 degrees I checked like 4 times!!! What the hell did I do????????????????????????????????????????????????????????????????????????????????????
sage2k
645
Baton Rouge, LA
Jun 5, 2007
  • Jun 5, 2007
the air filter oil may have got on the maf, clean your maf and see whats up
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jun 5, 2007
  • Jun 5, 2007
x2.....when i saw u re-did the filter this is what i guessed. Sounds like it for sure
Guero
2,148
Jun 5, 2007
  • Jun 5, 2007
ok i will check
HISSIN50
34
129
Jun 5, 2007
  • Jun 5, 2007
Is the SPOUT connector reinstalled?
Guero
2,148
Jun 5, 2007
  • Jun 5, 2007
Yes hissin. I just got back from work and I haven't cleaned it. But its running richer than normal and when I punch it its in the a/f 9.oo
Guero
2,148
Jun 5, 2007
  • Jun 5, 2007
Ok I cleaned it and it still runs like complete ****!!!!!! I did notice that when I put in setting 5 on the Tweever it does alot better at Wot but it idles like crap!!! WTF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Guero
2,148
Jun 5, 2007
  • Jun 5, 2007
Ok I forgot to mention that when I was setting the timing. I had to lift the dizzy and when it touched the block it sparked. After that I disconnected the battery and put it back in.....But i dont think nothing got burnt but who knows
HISSIN50
34
129
Jun 6, 2007
  • Jun 6, 2007
Guero, put a timing light on and ensure the timing advances when you put the SPOUT back in. The spark thing worries me - you could have fried the TFI, which makes you run at base timing.
Also, the twEECer guys can tell you, but do TwEECer files ever get corrupted? I figured they dont, but thought it was worth asking.
Good luck bud.
And thanks for the compliment on the fox vert. I didnt want to reply yet again on Nik's thread (and hog it even more).
Guero
2,148
Jun 6, 2007
#10
  • Jun 6, 2007
  • #10
About the Tweecer. If they did get some how corrupted, I re downloaded the same tunes back one. Ill check timing with the SPOUT on and see weres its at.
Yeah that fox picture you posted was very clean. I personally dont really like them but that one I really liked
Guero
2,148
Jun 6, 2007
#11
  • Jun 6, 2007
  • #11
I always get confused......The TFI is inside the Dizzy right??? Whats the thing called next to the Cold air intake next to the SPOUT??? Is that the PIP or is the PIP the same as TFI???
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jun 6, 2007
#12
  • Jun 6, 2007
  • #12
Our TFI is mounted below the cold air intake, but im pretty sure its connected to the dizzy directly. The PIP or pickup i believe its called is in the dizzy. I've never messed with it though. I'd check the timing like u're planning to do and if it checks out your problem must be elsewhere
Guero
2,148
Jun 6, 2007
#13
  • Jun 6, 2007
  • #13
Ok I checked timing with and without the SPOUT. Without the SPOUT it was at 10. With the SPOUT on I could not tell were it was at, it kept changing
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 6, 2007
#14
  • Jun 6, 2007
  • #14
With the spout in ... its supposed to look like that
I know this may sound hokey but
You do know there are two 10 degree marks on most hb's ... right
I mean ... anybody could over look a simple thing like that
Grady
Guero
2,148
Jun 6, 2007
#15
  • Jun 6, 2007
  • #15
Yeah I marked the right one. Which said 10 ADTC right?
Guero
2,148
Jun 6, 2007
#16
  • Jun 6, 2007
  • #16
What the **** man!!!!! I cant do **** to this car without someting going wrong!!!!!!!!!!!!!!!!!!!
R
red95gtconvert
382
Ponca city, OK
Jun 6, 2007
#17
  • Jun 6, 2007
  • #17
Nope, it should be 10 BTDC. Paint a white line on the 10* BTDC mark and re time your car, that should straighten it out.
Guero
2,148
Jun 6, 2007
#18
  • Jun 6, 2007
  • #18
no way!! ATDC stands for after top dead center right????
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Jun 6, 2007
#19
  • Jun 6, 2007
  • #19
Yes, but you want your spark happening BTDC.
Guero
2,148
Jun 6, 2007
#20
  • Jun 6, 2007
  • #20
I hope its at ATDC then lol!!! Ill go check
1 of 2 Next Last
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
