i just put my uca's in acouple days ago and now ive noticed that the car sits about a 1/4 in higher one the passenger side than the drivers side. what could cause this?
Did you at all touch the springs? You may have twisted one of them making the pigtail face the wrong way.
If you didn't touch the springs, did you tighten and UCA bolts when the suspension was loaded or unloaded? Try losening the bolts, placing jacks under the Rear axle, then torqueing the bolts down.
at first i tightened them with the suspension unloaded, then last night i put a jack under the axle loosened the bolts and tightened them back up again. it helped atlittle, which way should the pigtails be facing on the rear springs?
