ok guys i started the car up np drove to get some gas when i started the car up again to drive off i noticed a cloud of white smoke and i was like wtf got the car to look the cloud faded away drove home turned the car off and on again
no cloud i looked in my engine bay and noticed a little oil leaking from passenger side of valve cover but thats about it
car runs ok
is there anything else i need to check out could my car be telling me that something bad is starting
thxs
i did a search cant find what i am looking for
car runs ok
thxs
White is antifreeze, blue is oil, dark grey means the car is running rich and dumping some fuel out the tail pipes. The last one usually only happens when you're at WOT and shifting gears. Your's sounds like antifreeze. Check your engine oil. If it's kinda milky that's bad news, means antifreeze in the oil. If you start the car and let it run for a few seconds and check your dipstick to see if there is anything "frothy" about what's on it. It sounds like a good time to change your oil to check just in case. A few bucks on oil could save your thousands if it is a blown gasket. Good luck. I'm usually down about a liter of oil when I change mine every 5000km. Our cars tend to burn a little.
