Hello again to all,
I swear they should make my problem threads a sticky just because I have to post a new one everyday and it would save a lot of time!
Here we go again, today I changed the plugs and wires in my car...the plugs went to some accel plugs from brothers and the wires are FRPP 9mm also from brothers. The install seemed to be a cake walk and only took about an hour, car started and sounded fine so we took off for a little test drive.
As soon as we put it in reverse and got out of the driveway the car got a wicked wicked shake, the whole car was just vibrating like crazy, it was like a giant massage chair. Took it down the road to run it a bit and it just got worse, the car revved up really high several times and the CEL came on and off quite a few times as well. As we continued driving it sounded like there was something dragging on the ground behind the car, a constant rattle tat tat, SUPER annoying, though nothing was actualy dragging. Took it back home and got the OBD I reader (best investment ever) and pulled the following code:
172- Heated O2 sensor indicates lean condition, right side.
Okay so by right side do they intend driver or passenger? After I turned the car off there was a lot of clicking noise (not the usual engine cooling sound) on the passenger side of the car. Is this a simple case of something having come unplugged during the install or does it have something to do with the plugs/wires? I noticed when I pulled the old plugs that they all (except 5) were showing too hot (can take pic if you'd like). I have often smelled fuel when I start my car so I always assumed I was running rich.
I am also having a hell of a time getting the car to idle right, I have done the whole checklist and this is why the cap/rotor/plugs/wires swap of late, seems to have made things worse. Any ideas???
