  • SN95 4.6L Mustang Tech
Car Stalling
  • Thread starter Thread starter 2000perfredgt
  • Start date Start date Oct 10, 2008
2000perfredgt
10
  • Oct 10, 2008
For the last month my car has been stalling on cold starts. On first engine crank it stalls, but starts fine on the second attempt. No rough idling once started. It seems to happen more when it is cold or damp out. I'm thinking the IAC is going. Any ideas? Thanks in advance
evil281
276
Arizona
Oct 10, 2008
  • Oct 10, 2008
maybe try turning key to accessories and let the fuel pump prime and then a few seconds later turn the key and see if it starts right up, fuel pump may be goin out
2000perfredgt
10
  • Oct 11, 2008
Tried this this morning, same results, first crank stall, second starts fine. More info: battery and fuel filter are in good condition.
Cobra123089
94
Broomfield CO/ Laramie WY
Oct 11, 2008
  • Oct 11, 2008
i would clean the throttle body and iac with carb cleaner.
2000perfredgt
10
  • Oct 13, 2008
cleaned the iac with carb cleaner seems to have fixed the problem
F
FastMustangGT
53
Massachusetts
Oct 13, 2008
  • Oct 13, 2008
my car does that also but I have a cam in my car. Once I start my car I hold idle at 2rpms for about minute or two then its fine. Once snow comes forget it, car runs like crap it wont idle until it hits close to engine temp.
K
KW 2000 GT
WEATHERFORD,TX
Dec 23, 2008
  • Dec 23, 2008
I have 2000 gt that will stall after putting in drive but will restart with no problem. Also will surge after initial start up. On highway will cut off if I go thru a depression in the road. any answers, thank you
stang09er
115
Clarkston, MI
Jan 7, 2009
  • Jan 7, 2009
i am leaning toward your fuel pump starting to go on you my friend! i replaced mine already because mine was doing just as you said! i would hit a small incline in the road and it would just give up!
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
