Well I have found one of those problems that has me and alot of other people scratching there heads so any input would be great. We are dealing with a 393W with an auto trans that will idle a little rough at idle 1K, and will sing at 4K. The issue is when I put it in drive/ reverse the eng. wil make a couple of revs then dies. Will always start right back up. Now before you jump to any answers this is what has been done so far. Changed ignition system from pertronix to Accel, Carburetor stock to a Demon, Timing advanced/ retarded, fuel mixture rich/ lean, Eng. pulls 17 in. of solid vacuum, compression is 185 to 205, All vacuum lines plugged and no leaks, adjusted roller rockers three times, Changed trans. from FMX to AOD. After all these changes no difference.
The only thing I have noticed that is strange is some plugs are burning clean and some are sooting, and yes I have tried different plugs, I am leaning towards a cam issue, What do you think?
