I’m running a 289 with Throttle body injection and an electric fan.
I’m pulling my hair out. Here’s the problem, when my 65 gets completely warm after a drive for instance it begins to intermittently idle very rough at a decreased rpm and sometimes stop. When driving even on the freeway this has happened I couldn’t get the car past 40 mph. Keep in mind this problem does not always occur when the car is warmed up, only sometimes. Sometimes idle is fine and it runs great. When the problem is occurring and I rev it up it sounds much deeper than normal and becomes gutless. The alternator is keeping the battery charged even at extended idle with the electric fan running. I even tried a direct connect from the battery to the coil while problem was occurring but this didn’t help.
I tried sealing off all possible vacuum leaks by capping them at the TBI including the pcv and brake booster and the vacuum advance. Since the problem occurs at idle only when very warm I was thinking vacuum leak, but this didn’t solve the problem it would run fine for about 25 min at idle, then bad again. It appears there is no leak. So my next thought was ignition, I removed the Igniter and went back to points and condenser, problem still occurs. I tested my coil and it appears to be within specs. Cap and rotor look fine, plugs are new. I think the key is it only happens when hot. I’m not overheating by the way. With the TBI I had to run some more fuel lines any thought on the possibility of vapor lock? The fuel lines get pretty hot. Maybe plug wires?
Would not the same thing happen in the fuel lines if their subjected to high heat source?
