Car sways all over the road
  • Thread starter Thread starter Smurfstang88
  • Start date Start date Apr 4, 2021
First Prev 2 of 2
P
paul1392
vancouver bc
Apr 10, 2021
#21
  • Apr 10, 2021
  • #21
Smurfstang88 said:
Update: found a dorman rag joint at oreillys, had a fun couple hours or so taking the old one off and puttin the new on. Let me tell you what a world of difference. I just wanna say if anyone has the same sorta problems that I was having and you kinda think that could be an issue because everything else is goodnuff, its worth every curse word you spit while changing it out. It solved my issue and the wheel has no play that i can feel whatsoever. I dont feel like drivin my car off a cliff now(on purpose or on accident). So for the ones saying you should just drop the 300$ on the mm steering shaft instead of replacing it, nah i think its worth spending 9$ and a couple hours of fun with a beer every however many years it takes for it to give out again instead. Just my 2 cents
thanks for the update, I have the exact problem with my car. I bought a unisteer drive shaft, bumpsteer kit, inner tie rod ends and ball joints. Also MM caster camber plates. I havent installed anything yet. I hope once I get everything put together it will also eliminate this problem.
nickyb
I gotta say i never painted my nuts, Never Ever
3,040
1,668
163
nevada
Apr 10, 2021
#22
  • Apr 10, 2021
  • #22
I know the mm shaft is expensive for a street car but... There is an alternative. You take your stock one and bolt/ weld a universal joint on it. I belive junkyard dog (youtube) did one.
nickyb
3,040
1,668
163
nevada
Apr 10, 2021
#23
  • Apr 10, 2021
  • #23
Actually there are a bunch on youtube like, $20 ,$30, and the like,just look up mustang steering shaft u joint.
HemiRick
I'd be looking at jacking under the house
Jun 28, 2020
723
272
73
Memphis TN
Apr 10, 2021
#24
  • Apr 10, 2021
  • #24
Does that shaft have any slip joint in it, for the length to change? I read that the later rack had to have a slip joint in the shaft or it would start leaking at the input shaft.
First Prev 2 of 2
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
