I run Goodyear F1s, 275/35/18 all corners Eibach sportlines(2inchdrop), and mine tracks badly as well, I view it as a benifit, I always know exactly which way the road is sloped because my car wants to go that way.
As stated its a function, of wide tires, low profile tires, I do have MM, caster camber plates already.
To your question, I'm considering laying back the front sturts slightly, toward the driver, I believe this is actually called postive caster, your question prompted me to go back and re-read the MM CC plate install document then I checked by last alignment print out.
Stock Caster is 3 to 4 degrees positve, MM recommends, 6-7 degrees positive but cautions you could induce excessive bumpster if you go beyond 7 degrees, I think on my next alignment I'll have the technican pull my struts back to (postive caster) to 7 degrees, I'll report my findings in a week or so.
