Ford uses two types of transmission speed sensors. VSS and OSS.
The 1996-1998 uses a contact worm gear VSS sensor
The 1999-2004 uses a non contact reluctor wheel OSS sensor.
The output of the VSS sensor is NOT compatible to the OSS sensor. The wiring is different between the two sensor types. Plus the sensor type needs to match what the PCM is expecting.
Just wondering.........Does the speedometer work? What speed is the speedometer displaying at 54 MPH?
I really suspect that the car is cutting out because the PCM "thinks" that the car is going tooooooooo fast.
Research an extended range SpeedCal to convert OSS signal to VSS style.
Here's some more information that may help you to understand the difference between a VSS and OSS sensor.
T-45 Tail Shaft Swap
https://www.allfordmustangs.com/forums/4-6l-tech/140694-t-45-tail-shaft-swap.html
