Car will not start! NEED HELP!!
  • Thread starter Thread starter hotrodjoe
  • Start date Start date Jul 31, 2006
H
hotrodjoe
  • Jul 31, 2006
This is what i posted on the corral and i cannot seem to get any help so i am hoping someone here can help.
THanks
Keith
Well the car has been running great, no problems. I backed it out of the garage to clean it, then started it back up to put back in the garage. While idleing the car would just shut-off, like somone turned the key off, but before the tach would get to zero the car would come back on. So i reved it up a few times and while i was reving it, it would just turn off and you could here the suction of the TB when i wold pump the peddle to try to keep it running. SO i shut it off and left it for about an hr. Then it started right back up like nothing was wrong. I tried to take it for a drive after it had warmed up, i didn't make out of the driveway and it just shut-off and would not start. So i let it sit for about 30sec and then it started abck up again. Now it will not start at all. Turns over great and i have checked spark which i have. ALso when it is turning over the tach is moving. I checked the TFI and it is good. I checkd the fuel relay and it is good. I have fuel pressure at 40psi when cranking, I can hear the injectors firing. One other thing that happend today was when i was trying to start it. WHile cranking it almost started and then like died real quick but the injectors stayed firing, like i could hear all of them clicking. I turned off the key and then turned the ignition back on with out starting it KOEO and they started firing again. Real weird!!! After i turned the KO and back ON they quit firing. I don't know what else to start checking.
PLEASE HELP!!!!
OH one other thing. When it would run i pulled the MAF connector off and started it up and it would run but not idle and I cold hold it at about 3000rpms and it would never drop off like it was doing so i thought it may be the MAF. Now when i unplug it it still does not start.
during the no start condition i had my wife turn it over while i held one of the spark plug wires with a screwdriver in it to the camber castger plates to get a spark. Also when the injectors are firing the fuel pump is on. This happens a when you have key on engine off. I think it is the computer.
TODAY 7/31/2006
latest developments. Bought a used but in working order computer off this site (corral.net). Plugged it in and all seemed well. Car started right up and even sounded ok. Let it idel for about 3-4min, shut it off and tried to restart. NOTHING! I have spark and the noid light show the injectors firing. After about 15sec of trying to start again, it fired off. I then went and drove it around. Didn't feel as strong as it did before but still good. Shut it off in the garage and again will not start back up. I have a check engine light but cannot pull codes. FOr some reason when i hook up to pull codes nothing happens. Any help would be greatly appreciated.
KENS89LX
302
Cross lanes Wv
Jul 31, 2006
  • Jul 31, 2006
Check your grounds, sounds like one is loose. The one for the computer is on your ground cable hooked to the battery. Check your distributor there is a piece that goes bad inside, that will cause no starting issues.
H
hotrodjoe
  • Jul 31, 2006
If i had a bad ground would it have started at all? If the pick-up coil went bad in the dist would i have a spark? The orange wire that connects to the back of the drivers side head i found broke, so i connected it to the neg side of the battery and it still won't start.
HMMMMMMM!!!! What a challenge!!
-keith
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 31, 2006
  • Jul 31, 2006
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 30-Jul-2006 to include pip diagnostic help
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Killer50stang
632
  • Jul 31, 2006
-keith
Yes, loose connections will do crazy stuff. I had a similar issue on my car and finally found the bad wire. I would check your ingition wires as well (that's where mine went bad). How old is the dizzy?
H
hotrodjoe
  • Jul 31, 2006
the dist is the original one. I installed a new dyno module a while back. So at this point i will look at what jrichker said to do and check all loose wiring and will get back soon. This board has beena huge help so far. How do i check the ignition wires? Is their a wire diagram somewhere?
Thanks
-keith
H
hotrodjoe
  • Jul 31, 2006
OK i went out to do some of teh simple tests that jrichker said to try. I pushed the pedal 1/4" in and tried starting. Nothing. Then i pushed it to the floor and tried starting. IT started about 15sec later but is running good. While it was running i noticed a little smoke coming from the solenoid area. So i shut the car off and looked and found the black wire with the orange stripe was very hot. I also found that the alternator was also very hot could be from trying to charge the battery not sure yet. WEll i disconnected both the connectors from the alternator and the car started up first try. I started teh car 5 other times with no problems. So now what should i look to be a problem? I am not going to work on it any more tonight but will tomorrow and post back.
Thanks again for all the help.
-keith
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 1, 2006
  • Aug 1, 2006
-keith
Disconnect the battery & put it on charge overnight. Then connect everything back (watch that you don't connect it backwards) and start the engine. The black/orange wires are either alternator power feed or power to the computer. Since the car started, it sounds like the alt is bad. A failed computer would not let you start the engine. Check the voltage at the starter solenoid with a digital voltmeter. You should see 13.8-14.5 volts at 1000 RPM. Less means the alternator may have problems.
H
hotrodjoe
  • Aug 1, 2006
during the time that i was trying to get the car started i always had over 12.2v and higher. Anything below that i put it on the charger. After it was running i only get about 13.8v is the highest usually. I have a real time LCD display in the car for voltage. I will try to charge the battery more and reconnect everything and let you know what i find out.
thanks
-keith
H
hotrodjoe
#10
  • Aug 2, 2006
  • #10
charged the battery overnight. hooked everything back up. Car started right up. So does the system need acertain amount of voltage to start? I still believe something is wrong somewhere. I cannot pull codes from the computer and i am not getting a reading fromteh TPS although the car is running.
-keith
sharkbait87
#11
  • Aug 2, 2006
  • #11
Try your ingnition switch, its made of peuter and plastic. My car did the same thing. Its on the steering col. i lowered my steering wheel made it very easy. Mine fell apart as soon as i took out the screws.
H
hotrodjoe
#12
  • Aug 2, 2006
  • #12
well again the car stated fine. It seems as if it is in open or closed loop as it is running real rich. I let the car run until operating temperature about 10-12min. Shut it off and it will not start back up. I guess i will look at the ignition switch and see if something is wrong there. I also put the + side of my voltmeter on the + side of the battery and checked all over teh compartment, from my radiatior to bothe fenders and firewall. I always had 12.5v and above. Would this indicate i have a good ground?
thanks
-keith
H
hotrodjoe
#13
  • Aug 10, 2006
  • #13
WEll for those that care. The car seems to be fixed. I purchased another computer and all seems. I hope it saqtys that way.
-keith
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
