Car wont idle need help!!
  • Thread starter Thread starter 302pwr
  • Start date Start date May 16, 2004
302pwr
37
edison,nj
May 16, 2004
  • May 16, 2004
My 86gt is having problems idling. a couple weeks ago i drove the car around town, it was fine then started the buck and miss, now the car wont even idle. My fuel pressure is at 40psi. i changed the wires, plugs and bought a distributor with new tfi also new cap and rotor, new tps sensor. I got spark and fuel i have to let the car crank longer in order to start while im advancing the dist and hold the throttle open, then the car dies immediatly like after 10 seconds. Does anyone have any ideas?
302pwr
37
edison,nj
May 16, 2004
  • May 16, 2004
And
I scanned the car during koeo and got a 4? unknown code and code 14 pip continius code. I tried a koer but the car kept on stalling but it managed to detect that i have a 4 cylinder engine on the scanner display ??????? strange.
P
PRO50SC
1,012
Olney, Maryland
May 16, 2004
  • May 16, 2004
Are you sure the distributor is in the right spot and not a tooth off when you put it back in?
302pwr
37
edison,nj
May 16, 2004
  • May 16, 2004
follow up
I believe the distributor is in the right place. I turned to car over to TDC removed spark plug until i felt compression then left the balancer on 0 degrees then put the distributor in trying to align the rotor to #1 cyl. Aprrox. what degree should the dist. be at when facing #1 at tdc 0deg ?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
