Car wont idle
  • Thread starter Thread starter Dean85GT
  • Start date Start date Sep 8, 2005
Dean85GT
502
Thorold, Ontario, Canada
Sep 8, 2005
  • Sep 8, 2005
Great. A new problem has developed but I think I know the culprit. Anyways, I was emptying my ps fluid tonight to see if I could quiet it down a bit. So I filled it up and went for a spin. About 3/4ths the way home the car just died. I was like ok, I must have ran out of gas (I had 1/8th a tank of gas). So I coast it home and go to the corner to get some gas. I get some gas for the car and the problem is still there. So basically whats happening is the car won't start unless you hold the starter for awhile and pump the gas a bit and the car idles at <500 rpm or simply dies. Now, when I was emptying the ps fluid I spilt some on a connecter coming from the ignition box. I cleaned it pretty good but I will try again when its light out tomorrow. Do you guys think that this single handedly is screwing over all that. The car runs fine as long as its not idling. It has full power everywhere. Hopefully some contact cleaner will be able to solve it, otherwise I don't know what it is. (this is a carbed car btw)
Dean85GT
502
Sep 8, 2005
  • Sep 8, 2005
Oh and I forgot to mention that every couple of weeks the car just wont start. Period. After about 5-10 minutes of leaving it, it starts (and no its not flooded). It always seems to happen at the most "convenient" times.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
