Green 94 5.0
have you also checked to make sure none of your plug wires are crossed? i had a similar problem during one of my headswaps and it ended up being that i had the #1 and #2 plug wires backwards. symptoms were surging, stalling, popping in the intake, and absolutely no power at all. by no power, i mean that when i actually managed to get it to drive a little, it felt slower than a stock honda civic. also, when i mentioned the plugs i assumed that you had bought the gt40x aluminum heads. im not sure about the correct plugs with the gt40p's.JOEGTS said:I pulled the Hypertech chip out and the car will idle somewhat, but pops like the timing is off. I tried to start it with the Spout pulled and it won't start. I will try to set the timing again when i get a chance. I was told that Iron GT40 heads use Autoliye764's?![]()
