Car won't start after being garaged
bmo37
2,368
New Jersey
Over the coarse of a few years I put together my project car (mods in sig) when money was available. During the end of the completion stage I had the car running consistantly but fairly rough due to no tune. I bought a tweecer system and fiddled around with it. Over time the the car sat idle for about 5 years only being started maybe once or twice with the first 2 years of sitting. Now owning my own house and garage to work in I decided to try and resurect this old beast. For the life of me I can't get the car to come alive again below is what I've done and any other info that might be helpful. Any help is greatly appreciated.
Prior to storage gas was emptied and small amount left in tank about 1/2gal had staybil in it.
When car was built I replaced almost every component related in the fuel, air, and spark area. New fuel pump, fuel filter, spark plugs, ignition coil, air filter maf, injectors, air filter, oil filter, oil, coolant, etc all consumables and sensors.
Recently I replaced the battery cause after 5 years of sitting the optima red top was dead. I checked all the gounds (fender, block, firewall) and live red wires started and solenoid.
Battery has around 14.5v cross terminal, under cranking load hold 14.3v. Fuel pump activates for about 3-4 seconds during ignition on than turn turns off as it should.
Jumping starter screw to solenoid main coil wire generates a spark as does #5 spark plug while test starting.
checked that distributor was at the number 1 plug at TDC on the compression stroke. Even tried to flip it 180 out of phase just in case timing marks on blancer were wrong or if timing chain was mis aligned.
Car cranks but won't start up. Car started briefly during the first inital try last week. Pretty much reved to 2k sounded like crap, smelled like a alot of flooding going on and never came on again. I checked the msd rotor and cap, they looked alright the cap had some black burns on the innern tabs which the rotor passes and arcs on. I removed the cap and sand papered them so the brass was clean for a good connection. Alos when I pulled a few of the plugs they were fouled. assuming from me continously trying to start the car with no success. I filed them but it didnt help.
I reset the car back to the orignal A9L base tune, I've tried my own custom to to adjust for the larger 42lb injector and startup tables. I lowered the fuel pressure down to 32lbs and nothing will work kinda out of ideas.
Removed my vaccuum/boost gauge and simplified my vaccumn lines to rule out any leaks due to the supercharger vaccuum routing. Running a bypass valve. Car when it did run ran a little rich due to the fuel injectors and unmodified parameters on the ford eec and had to give it throttle to keep it alive sometimes.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 26-Jul-2008 to add new links to AutoZone ignition wiring for 86-88 model cars
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
I.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
J.) Computer
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715f.gif
Computer/fuel pump wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif[
Ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167163.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=az/cds/en_us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
thanks for the info I actually read through all that before posting but it didnt seem to help. I'm really starting to grasp at staws here, aside from the eether into the tb and injector harness (doubt cause plugs are fouling due to flooding) testing with a noid light im starting to go crazy. I removed the inlet tube from the supercharger to the throttle body that didnt help. Im going to look at the tps voltage tomarrow. I think im going to take the tweecer out and just try the stock ecc by itself. Even starting to think maybe my spark at the coil or pugs arent strong enough, im not running an aftermarket ignition (maybe i should) and running a .045 gapped plug with colder heat range for boost apps. I can see a spark at the coil wire and the number 1 spark plug wether its 3/8" i cant really tell.
Once you are sure the TPS is working properly, press the throttle to the floor and hold it while cranking the engine. This will tell to computer to turn off the injectors and clear a flooded condition.
Try putting the stock coil back on and see if that makes a difference. I have had a coil go bad, and it made spark, just not a nice fat blue spark.
