Car wont start after blowing out spark plug
question..
well one of the spark plugs unscrewed itself. the threads are fine but it wont start, it turns over fine but it acts like its out of gas or something. what do yall think?
What year? Is it COP? having one plug out can blow the coil since that plug can't fire. Non-COP motors can see this. COP motors can blow ignition electronic if you don't ground the electrode when turning the motor over. All that spark energy has to go somewhere, and it can break down the inside of the coil and go back to the ignition module and blow it out.
First check is to see if you are getting a spark at a plug...
Fuel reset button in trunk maybe? not sure why it would do that
i tried that button today, it was already pressed down is that how its supposed to be?
its a 2000 and has coil packs, where is the ignition module?
also isnt the fuel pump supposed to make a noise when the is key turned but engine not on yet? i couldnt hear the fuel pump i checked the fuse its not blown could it be bad?
