Well, title says it all. After putting lt's and my tko in I'm having some starting issues.
When I first tried to start the car it wouldn't crank. So I went to jump the battery. (FWIW its Relocated in the trunk). And smoke came up from the drivers side fender where the solenoid thing is with the two terminals where the starter connect too. I forget what its called. But the car wont start with the key. Only with the car in the on position and if I hit the solenoid thing with a screw driver. Anyone know what it could be. I actually got it to start after with the key once but not again.
When I did get it started. The battery light was on and I drained the battery going around the block and and back to the garage. It didn't die but in no way did the battery have enough life to crank over the motor again. I borrowed my buddies battery out of his 96 gt and the same things were happening so I know its not battery related but with something else.
Anyone have issues with this. This is my first fox so im not farmiliar with some stuff. Even though is has a 5.0 like my 95 everything is a little different.
Dan.
Dan.
or look more into that starter solenoid on the fender well. good luck.
